820-01521 A1932 boots only in safe mode
jadao
Hi there, this was a liquid damage with PPBUS shorted at u7430 (Pin 5 CPUGT_BOOT2_RC was burned shorted with ground along with pin 6 PPBUS_HS_CPU).
There was also minor corrosion at other spots like PMIC an TPS51980.
Replaced U7430 and short gone. Cleaned also corrosion everywhere.
The board is fully booting only in safe mode. Otherwise it will boot at 75% (progress bar) and just restarts, same thing with external MacOS.
Also it can boot windows with no issue. I can load the boot menu with option key or perform a recovery mode.
Tried to disconnect everything piece by piece nothing changed, (I/O, trackpad, keyboard, battery) only internal lcd left to try and use an external monitor.
Tried a successful DFU restore but nothing changed also. AHT test comes with no error found.
Should I conclude for another dead CPU? :(
There should be a problem with a device which requires the driver loaded by macOS.
Once booted into Windows, start installing the drivers.
See which one causes the restart.
I suspect iGPU, as U7430 is part of its power supply.
Just in case, check all resistors, caps and traces around U7430.
Pay atention to R/C7439 and R7437.
