820-01521 don t wake up after lid close
Dozer
got this unit with high fan spin. found bad battery. after replacement fan is ok.
when i click on the sleep mode, the device goes into sleep mode and wakes up again normally. but when i close the lid it also goes into sleep mode, but after opening it, the display remains dark.
i have already installed a new speaker, assuming the hall sensor is the problem, but the result is the same. then i changed the audioboard, but no change. the original audioboard has a white headphone jack, but my replacement board has a black jack. are there any differences? in diode mode, the readings on the speaker connector are the same.
Dozer
tryed in another case and all is ok.
Found there is another sensor left side nearby the microphone. after replacing the microphone all is working.
Problem solved
