820-01521: Liquid Damage
baker_jeff
First time working on one of these, oh boy (Late 2018 MacBook Air).
Liquid hit in the U3200. One one USB-C port, 5v @ 0.001amp. The 2nd port would flash on/off/on/off.
I replaced U3200 and a couple of the small caps and resistors in that area that looked gross. Now, both USB-C ports show 5v @ 0.03amp, but occasionally it will flash on/off/on/off on the one port still.
I'm getting my LDO outputs on both CD3215s.
TBT_PWR_EN is 0v. Should I be following this or am I barking up the wrong tree?
Thanks in advance!
Jeff
Coming back to this one. Things "look" clean. No broken traces that I can see, no really nasty components. Should I be hunting down TBT_PWR_EN?
Which is the exact ohm value to ground at PP1V8_SLPS2R ?
What about other AWAKE and SLPS2R voltages, any pulse at least?
In resistance mode: PP1V8_SLPS2R is 0.9ohm
I happened to get in a working board (yay!) and it is getting 4.5kohm.
I injected shy of 3v and can't find the damn problem even using Flir. Lots of areas getting warm... but nothing on this line.
Well... yeah. I bumped it from 1.8 to 2.8 as nothing obvious was showing up... unwise judging from your response?
You should get something like 2A ( a bit more) for 2v.
Something should heat with 4-5W.
Did you remove heatsink?
