820-01521 no backlight after close/open lid
On the lid bezel should be placed a magnet which go close to the hall sensor area, when lid is closed.
Find the magnet position with a screwdriver.
mbcontrol
I found it - it's in the speaker case - I broke one to see.
I changed the audio board, the speaker/hall-sensor and the flex to the MLB two times with known good parts.
mbcontrol
Yes, when lid is closed SMC_LID_RIGHT is low (measured at Pin1 of R4805)
when it's opened SMC_LID_RIGHT is 1,801V.
I also checked SMC_LID_LEFT (measured at Pin1 of R4804)
same values
mbcontrol
IPD_LID_OPEN is always high :-(
I changed the U4802 two times from Donor. Maybe they was both bad? Or could there be another problem with IPD_LID_OPEN?
U4802 MUST pull down its output, when both inputs are low.
Check surrounding traces.
Disconnect J6700 and check again.
mbcontrol
Disconnecting J6700 had no effect - still 1.8V (open and closed).
The traces arround U4802 are ok - but i'll have a look again
Replace U4802 again, just in case.
Be sure to use correct (OR) chip; both inputs must be low, to get output low.
mbcontrol
replaced U4802 again (from Donor 820-00426 U8170)
whatever i measured before when i told you that SMC_LID_RIGHT is low when lid is closed ??!!!
Now i have 1,409V as low-signal (measured at R4801 Pin2) and 1.518V as high-signal.
I can't find the reason for SMC_LID_RIGHT not going low. Could it have to do with the T2-Problem? It's the line we was going down from 1M to 1K with R4801.
It should go low when right hall sensor is activated.
That happens when the magnet from the lid go close to the sensor.
