I found it - it's in the speaker case - I broke one to see.
I changed the audio board, the speaker/hall-sensor and the flex to the MLB two times with known good parts.
IPD_LID_OPEN is always high :-(
I changed the U4802 two times from Donor. Maybe they was both bad? Or could there be another problem with IPD_LID_OPEN?
replaced U4802 again (from Donor 820-00426 U8170)
whatever i measured before when i told you that SMC_LID_RIGHT is low when lid is closed ??!!!
Now i have 1,409V as low-signal (measured at R4801 Pin2) and 1.518V as high-signal.
I can't find the reason for SMC_LID_RIGHT not going low. Could it have to do with the T2-Problem? It's the line we was going down from 1M to 1K with R4801.
