820-01521 stuck 5V draw 0,358A
Dozer
Hi got this board without any signs of liquid damage, looks nice.
one port working 5V, 0,358A stable (U3200)
other port 5V 0,535A about 30seconds and restarts looping (U3100)
I have power in port (U3200)
PP3V3_G3H_RTC 3.3V
PP3V3_UPC_XB_LDO 3.3V
PP1V1_UPC_XB_LDO_BMC 0V
R3450 1.68V both sides
R3460 0V
connector upside down
R3450 0 V
R3460 1.68V both sides
I have power in port (U3100)
PP3V3_G3H_RTC 3.3V
PP3V3_UPC_XA_LDO 3.3V
PP1V1_UPC_XA_LDO_BMC 0V
R3430 1.68V both sides
R3440 0V
R3430 0 V
R3440 1.68V both sides
need some help please
Dozer
PP1V8_UPC_XA_LDOA is 1.8V
PP1V8_UPC_XB_LDOA is 1.8V
PPBUS_G3H is 12.26V Diode mode .431
diode mode:
PP1V8_UPC_XA_LDOA .505
PP1V8_UPC_XB_LDOA .507
PP3V3_UPC_XA_LDO .485 3.25V
PP3V3_UPC_XB_LDO .407 3.31 V (compared with a good boar have A and B almost the same value in diode mode)
PP1V1_UPC_XA_LDO_BMC .491
PP1V1_UPC_XB_LDO_BMC .495
PP1V8_UPC_XA_LDOD 1.8V .353
PP1V8_UPC_XB_LDOD ->? 2.67V .409 (compared with a good boar have A and B almost the same value in diode mode and same Power 1.8V)
so seems the U3200 has to be replaced.
is it possible to take one of a donor board or it has to be the same board and the same position?
Dozer
So, I replaced U3200, toke from a A1708, everything fine now. Device is working again.
Thanks for your help, this case is finished
Dozer
oh men! thanks for the hint, I was lucky its C00 and the donor was C00 as well, i have another A1708 board there it is B03.
thanks a lot
