I got water damaged A1932 ( 820-01521 board). Motherboard itself had only few small spots of liquid around L7670 and J6620, the rest literally looks perfect. I found out that the battery is dead and needs to be replaced along with trackpad and trackpad flex, which were corroded. I put new parts, computer is working fine except trackpad haptic - it does not make "click" when pressed. In the system, the click function works (it selects things), but trackpad does not vibrate. I have already tried other trackpad, other flex and put motherboard to known good topcase and the result is the same. I have compared diode readings of J6700 with other working board and readings are exactly the same. I have Inspected areas of T2 - no signs of liquid there.. Any ideas?
