820-01521
I know which one you mean, the one connected in the J8500 to the LCD pcb.
I changed it and it's still the same.
They changed the keyboard on this machine, the strange thing is that I tried another board on the same base and it works.
Could it be a BIOS issue?
T2 machine, you can't touch BIOS there.
If you are now sure is ALS issue, need to check continuity on its SCL/SDA lines.
Also check R8556/58.
those lines have continuity from end to end.
both from the resistors to the J8500 connector and from the resistors to the capacitors.
Values in diode 521 both lines
33 ohms in both
well this case left me unsolved but I'll be waiting if another one arrives, deliver the equipment like this.
I reflowed the lcd connector on the motherboard, I think maybe one of the pins was not making contact, I would have changed it. But good for next time. Thanks for your help @2informaticos
I have the same problem here.
In my case as well, the voltages are 1.8 V and the resistance values are correct.
I have two MacBook A1932 units, and I replaced the mainboards in both of them. After that, the ALS sensor no longer worked.
I have now found out that the 2018 and 2019 versions are not compatible with each other. For example, if a 2019 mainboard is installed in a 2018 device, the ALS sensor no longer works. As a result, there is no keyboard backlight and no automatic display brightness adjustment.
The same applies the other way around: if a 2018 mainboard is installed in a 2019 device, the ALS sensor also does not work.
I just wanted to add this information here in the thread in case someone else runs into the same problem in the future.
