820-01598 no backlight.
Kyle93
Arrived with very little liquid damage on lcd connector. Works fine with external.
PPVOUT_S0_LCDBKLT only .567V
D8410 pin 1 0.050V pin2 .567v
EDP_BKLT_EN 0V
No short to grounds and already replaced LCD cable. Screen and board connectors look good
PP5V _S0SW_LCD 5V
What next??
3V3_S0SW_LCD present too?
Do you get image at least?
DP_INT_HPD goes high?
I bet for damaged CPU eDP output.
Check diode mode to ground on eDP lines of J8500.
Kyle93
3V3_S0SW_LCD was 0v Replaced u8501 now 3V3_S0SW_LCD 3.3V
DP_INT_HPD 3.3v pin 1 R4830 but 0v on pin 2. R4830 measures good.
LookS like Q4830 needs to be replaced.
Im assuming Q4830 cant be replaced from A 820-00850 since this one uses a SSM6N15AFEAP and 00850 uses DMN5L06VK-7
Know any other donars by chance that have the correct chip or sounds like this will have to be special ordered??
Don't expect the same voltage for XDP_DP_INT_HPD as for DP_INT_HPD; depends of DP_INT_HPD_MASK level.
Do not change Q4830 without reason.
As you now have 3V3_S0SW_LCD, check EDP_BKLT_EN and backlight output voltage.
