820-01598 - No display 20V 1.6amp on battery
ronaldo
The PP2V5_NAND_SSD0, PP0V9_SSD0 and PP1V8_IO_SSD0are not cycling.
I forgot to mention that I've tried Revive and it gone trough all the process with no errors.
Is there any way to make sure the SSD is the problem.
ronaldo
PPVIN_S0SW_LCDBKLT - 0V
PP5V_G3S - 5.11
PP3V3_G3H - 3.31
CHGR_LX1 - 12.63
CPUGT_SW1 - 0
PVCCEDRAM_PHASE - 1.02
PVCCEDRAM_PHASE - 0
PPVCC_CPU_PH1 - 0.81
PPVCC_CPU_PH2 - 0.81
PPVCCSA_CPU_R - 1.02
PP0V95_S0_CPUVCCIO_REG_R - 0.95
P1V2_PHASE - 1.20
PP2V5_NAND_SSD0 - 2.52
None of then are cycling.
Tested with another display and nothing.
So you get even CPU core voltage.
I don't have any working board to check the correct value.
But your reading doesn't look bad; 0.8V can be good enough.
Check USB activity, at least.
