820-01598 - No display 20V 1.6amp on battery
The PP2V5_NAND_SSD0, PP0V9_SSD0 and PP1V8_IO_SSD0are not cycling.
I forgot to mention that I've tried Revive and it gone trough all the process with no errors.
Is there any way to make sure the SSD is the problem.
PPVIN_S0SW_LCDBKLT - 0V
PP5V_G3S - 5.11
PP3V3_G3H - 3.31
CHGR_LX1 - 12.63
CPUGT_SW1 - 0
PVCCEDRAM_PHASE - 1.02
PVCCEDRAM_PHASE - 0
PPVCC_CPU_PH1 - 0.81
PPVCC_CPU_PH2 - 0.81
PPVCCSA_CPU_R - 1.02
PP0V95_S0_CPUVCCIO_REG_R - 0.95
P1V2_PHASE - 1.20
PP2V5_NAND_SSD0 - 2.52
None of then are cycling.
Tested with another display and nothing.
So you get even CPU core voltage.
I don't have any working board to check the correct value.
But your reading doesn't look bad; 0.8V can be good enough.
Check USB activity, at least.
