820-01598 no power
Kyle93
Arrived with liquid damage primarily in U6903 area. Replaced U6903 and all affected components. When turned on PP3V3_G3H and PPBUS_G3H are fluctuating drastically including CHGR_EN_MVR. stuck at 5V on charger.
What should be checked next?
TCRScircuit
Super Moderator
1. The rails on these machines usually cycle when there is a short somewhere. Post Resistance to GND values on PP3v3_G3H, PP3v3_G3H_RTC and PPBUS_G3H.
2. Do you have steady 5v on PPDCIN_G3H?
Kyle93
5v is not steady on meter
Resistance to GND PP3v3_G3H 1.580 PP3v3_G3H_RTC 1.2 PPBUS_G3H 10.30 million
Fuse removed
C7050 12.36v
c6912 0v
"PPBUS_G3H 10.30 million"
Do you mean short to ground, when F7000 is in place?
"Fuse removed
C7050 12.36v"
Good enough, because of missing 3V3_G3H...
"c6912 0v"
Post U6903 voltages.
Use surrounding components as test points.
Kyle93
No short to ground on PPBUS_G3H .400 diode mode with fuse in place
PPVIN_G3H_P3V3G3HRTC flucuates .700V to 0V
P3V3G3HRTC_PHASE1 fluctuates from .200V to 0V
P3V3G3HRTC_PHASE2 fluctuates from .200V to 0V
P3V3G3HRTC_PGOOD fluctuares .600V to 0V
P3V3G3HRTC_FB FLUCTUATES .200v TO 0v
CHGR_EN_MVR flucuates 2.2V to 0v
Sorrry, I forgot this is T2 board.
PPBUS_G3H MUST appear first; is the "mother" of all voltages, including 3V3_G3H.
"Resistance to GND ... PPBUS_G3H 10.30 million " (miliohm to ground???)
No short to ground on PPBUS_G3H .400 diode mode"
Can you clarify this???
Kyle93
PPBUS_G3H also is fluctuating however it is stable at 12.36V if R6907 is removed
Yes no short on PPBUS_G3H .400 diode is correct
C6912 voltage?
"Resistance to GND PP3v3_G3H 1.580"
What's that, ohm, Kohm?
Post diode mode (red probe at ground) on pad1/R6934.
"C6912 11.05V"
More than needed to fry T2, CPU and god knows what more :(.
Check R6912/13 values (ohm mode).
So you have short on 3V3_G3H.
I hope you understand the need of posting correct/useful information now.
You can use voltage injection method, to find the culprit.
Take your time and read the forum, if you are not sure how to.
If is not T2/CPU, you can spend some more time with this board.
However, MUST get correct C6912 voltage, before resolder R6934/35!!!
Kyle93
When injecting voltage looks like U7800 is getting warm. Is this chip possible to replace?
Set power supply to 3V at 5amps. Put positive wire on pad 1 of R6934
Read more about voltage injection on the forum.
If not, you can risk to fry something in the future!
Remove U7800 and check if short gone.
If yes, replace the chip.
Not sure if have board specific firmware.
Just in case, take one from donor, same model board.
Kyle93
Can you send link on what to read for injectuing voltage in situations like this? Always thought it was as simple as injecting the power into the rail unless its PPBUS_G3H and in that case check the mosfets first.
where do you get donars for this model? I haven't had any luck finding them
Start injecting with 1V and increase slowly, if needed; do not exceed 4V.
Set amp limit to max on the PSU first.
Getting T2 scrap board is really dificil...
