820-01598 No Power
bls951
This is a warranty repair that initially had liquid damage around Q8100, the rest of the board was clean. After cleaning up that area every worked great until recently. It did have a bad U7800 when it came back a second time. U7800 was causing all the slp, wake, g3h to jump, and caused pp5v_g3s and p3v3man_pgood to being missing all together. After changing it I get the voltages below now. It is stuck at 20v 0.03A. I have tried a revive and restore in DFU mode but both give an error of code 9.
PPBUS_G3H = 12.63V
PP3v3_G3H = 3.29V
PP1V8_SLPS2R = 1.8V
PP1V8_AWAKE = 1.8V
PP1V1_SLPS2R = 1.1V
PP0V8_SLPS2R = 0.79V
PP3V3_AWAKE = 3.29V
PP1V2_AWAKE = 1.19V
PMU_PVDDMAIN_EN = 3.3V
P3V3MAIN_PGOOD = 3.26V
PP3V_G3H_RTC = 3.0V
PCH_RTC_RESET_L = 3.0V
P5VG3S_EN = 1.8 V
PP5V_G3S = 5.109V
PP2V5_NAND_SSD0 = 2.5V
PP0V9_SSD0 = .9V
PPVCCQ_ANI_SSD0 = 1.8V
Any suggestions? Thanks in advanced.
Did you follow all the advices from DFU tutorial?
Post a picture of the error message you get.
If you can't complete DFU, there can be a problem with SSD, or T2 itself.
Possibly accumulated crap underneath.
bls951
I have tried multiple cables, multiple macbooks with different versions of macOS installed.
I'm going to look over the board again to see if there's anything obvious that I'm missing.
Thanks.
Corrosion always advances in time.
May have problems under T2, or U7800.
Can you access the machine in Target Disk mode?
