820-01598 no restore T2
iClub
The client tried to format and install Catalina and ended up locking the mac, I tried to restore the T2, but it shows the following error "AMRestoreErrorDomain error 9 - Failed to receive a message from the device, might be a connection problem with USB host. (Communication error, possibly USB disconnection).
Did you exactly follow all the steps from the tutorial?
Try another connection cable.
Be sure all AWAKE and SLPS2R voltages remain steady.
I'm not sure about your reply.
In pure english, it means that you can't put the machine in DFU anymore.
Is that true?
iClub
maintenance expired.
It could be a defect in the CD3217, as the error is referring to a lack of communication on the USB-C.
iClub
This mac I managed to restore and install macOS Mojave, but the client installed Catalina and started showing kernel error. Since then I can't restore anymore.
Then should be T2 internal problem.
Strange that doesn't allow DFU anymore, but you can expect weird things from Apple...
