820-01598 water damage no backlight
yair37
was bad damage no U8400 and around i was clean and make some jumpers.
PP5V_S0_BKLT_D - 5V
BKLT_EN_R 0V
PP5V_G3S 5V
BKLT_SCL 5V
BKLT_SENSE_OUT 0V
LCDBKLT_FB 0V
BKLT_PWM_KEYB 0V
XW4810 MISSING..IMPORTENT?
BAD U8400?
Do you have continuity from R8431 to D8410???
Their pins are marked in schematic/boardview, use a buzzer to check...
Then XW8410 is good.
You should try changing U8400.
Be sure all solders and traces are good.
May need to replace all surrounding resistors.
yair37
UPDATE:
finally there is back light...but now its stuck on apple logo for 1-2min and fan goes high and shout down.
was enter it to DFU mode try to revive and its stuck on 90% load and give error 1.
there was also very tiny water damage near U5802 there was just one damage line that make a jumper.
If no data on SSD, then try DFU restore, instead of revive.
If you need to recover the data, start in Target Disk mode and check if can get access to SSD.
