820-01598 Wont load OS
No-Clean
Clean board, Apple logo comes up but OS never loads.
Reviving T2 gives error.
NAND voltages are present and correct:
PP0V9_SSD0
PP2V5_NAND_SSD0
PP1V8_IO_SSD0
PPVCCQ_ANI_SSD0
Any liquid sign on the audio board?
Remove and check it on both sides.
Touch ID may cause problems too.
Test the board with J6600 disconnected.
No-Clean
All is fine with this Mac, I put it back in its case same thing, tried restoring again and same problem, I then put it into another Mac case and board booted up no problem, I then put it back in its case and it is working fine now, I did not even do anything, the only problem is that the camera does not work, but so far the Mac is working fine, this blows me away.
