820-01700-05 Top ports 5V, Bottom Ports 0V. Replaced blown CD3217. Now 5V on each port. Still no power
CGid
I have an 820-01700-05 that came in for now power. Upon checking the ports, the top 2 ports would get 5V ~200-300mA current draw. Bottom ports would give 0V.
After opening it up, we found the bottom ports' corresponding CD3217 ICs were blown. (PP3V3_G3H_RTC_X shorted on both with visible hole in the ICs)
I replaced both chips from a donor. Same location, same IC, same board number.
Now I get 5V on each port with around a ~250mA current draw.
PPBUS - 12.29V
PP3V3_G3H - 3.3V
PP1V8_SLPS2R - 1.8V
I attempted forcing the system to DFU via an external button. The device goes into DFU mode (1.8V measured on SOC_DFU_STATUS to confirm) , but is not detected by Apple Configurator.
Any thoughts on what to do next?
CGid
Reflashed both ICs. I now get 20V on all ports but hover around a 62mA power draw. Only chip getting warm under thermal is T2.
I can still go into DFU mode and get 1.8V on STATUS to verify. However, I still can't see the system connected via Configurator.
CGid
The DFU cable I'm using I've used for at least four other Macs prior to this one. And it's still in quite good condition. I'll try it out though
