820-01700-a
tili1988
hello i have macbook a2141
the problem is , the fans start bat the macbook does not turn on .
L7211 0 VOLT
U7210 0 VOLT
R7216 IS 5V
I DON'T UNDERSTAND WHY U7210,U7410,U7420 IS BLOCKED ?
THAN KYOU
Why did you touch U7210?
Did you get RAM and PCH voltages, to search for CPU core?
You didn't mention other voltages, apart of fans runing.
Really strange to get fans runing, but can't complete DFU.
Did you exactly follow all the steps in tutorial?
Be sure to use original 96/140W charger.
Connect the correct charger to the target machine.
Also, be sure to connect USB-C cable for DFU to dedicated port.
Do not expect image on target machine, when in DFU mode.
Be patient, sometime is not easy to get it in DFU...
tili1988
L7211,L7221 I DONT HAVE VOLTAGE IN RALITY IS 1.5V
THE SOFTWER FINISH END I HAVE THE NEST FOT I SENT APPLE CONTROL, I DONTE HAVE ERRORE
WHAY I MISING 1.5V IN L7221 , HU GENEREIT 1.5V FOR THIS LINE ?TELL ME WHAT ELSE CAN I DO
Please, stop writing in capitals an entire message.
Try to make you understood more easy.
As I said, CPU core voltage is on tha last to appear; only iGPU core will come later than it.
Do you get L7700/01 and L7330 voltage?
BTW, why do you expect exactly 1.5V on CPU core?
This voltage is dynamically adjusted.
In fact, it must drop to 0.55V when board boots.
