820-01700 boot loop
iClub
I have already restored several times the T2 in DFU mode, but no result, do you have any idea what it can be?
iClub
When you are in the CMD+R screen the mac doesn't turn off, only after you install macOS.
iClub
The installation is not interrupted. When it starts for the first time, the Mac reboots.
The installation was done over the internet.
iClub
The board is perfect.
The customer reports that he is using it and turned it off out of nowhere. The cooler suddenly speeds up.
Possibly GPU issue.
I suppose its driver is not loaded booting in safe mode.
Check how it appears in system report.
Mmmmh, looks like AMD graphics is in use.
Test the machine booting in normal mode, with external monitor connected.
Try to discard peripherals issue.
Test first with external monitor, disconnecting internal LCD connector.
In safe mode, run HWMonitor and post screenshot with all values
Adjust security settings to allow USB boot and test the machine with USB macOS.
Try to switch between GPU/iGPU with gfxcardstatus, if possible.
Can you login into macOS starting in SMC bypass?
