820-01700 no backlight + other issues
nininunz
It's got dust on it from sitting so I'm gonna dunk it in the ultrasonic and see if that changes anything.
What is the exact resistance to ground on PPBUS_G3H?
Compare with values on all big coils; including L9080/580.
nininunz
What am I comparing on L9080? Like PP2V5_NAND_SSD1 to ground? to ppbus_g3h? to PP2V5_SW1_TPS62180_SSD1? Sorry for my ignorance.
ppbus_g3h to ground when I first touch its about 5ohms then drops to 3ohms after 2-3 seconds then settles around 2.5ohms, but when I hold it a long time (20+ seconds) it keeps creeping down, got down to 1.9 before I got too impatient after about a min.
Allow 10-15s once power is removed, before checking in diode mode, or ohm scale, on any power rail.
Considering 3 ohm to ground at PPBUS_G3H and apñrox same reading on L9080 (or any other coil), you have two options when testing between PPBUS_G3H and L9080 (or other coil), in ohm scale: 6 ohm, or 0 ohm.
In other words, you will get the sum, or difference of the readings to ground.
If you get the reeadings difference , which can be 0 ohm in this example, then you have a short between PPBUS_G3H and corresponding coil.
It can be caused only by the power chip connected between both rails; an high-side MOSFET, or power IC.
In case of very low reading on a coil, you can also compare with good board.
3 ohm on L9080/580 is very bad; short for sure and damaged power IC, NAND chips, or filter capacitors.
However, CPU/GPU coils have very low resistance as normal.
nininunz
This is minutes after power is disconnected. It will do this every time I check.
Diode mode between ppbus_g3h and L9080/580 is both .460
My thought was the short could be a mosfet because there was no discernible heat coming from anywhere on the board.
Sorry, I don't understand what you mean. Mind explaining?
nininunz
I'm an idiot, I really do apologize for wasting your time. A jumper I ran some time ago came loose when I was cleaning corrosion in the area and it seems I soldered it one pad over from where it should've been, a ground pad :|
Now to tackle yet another issue I created on this board. Some components by U4900 and U4920 blew away when I was removing U4920 to clean up a corrosive mess.
nininunz
Turns out I did actually have it in the right spot. I'm so sick of this board. I removed CB702/3/4 as that's the area my jumper was in and PPBUS_G3H to ground is now 0.1ohms.
0.1 ohm shouldn't be through an high-side MOSFET, or power IC.
However, check first if you don't exact same short on any coil; don't forget L9080/580.
If none of them gives such short, then is safe to inject voltage into PPBUS_G3H.
Anyway, start with 1V and slowly increase if needed.
Set amp current to max first.
