820-01700 no power 5V 0.22amp no dfu SOLVED
got very slight corrosion on some caps (ssd area) but nothing serious (no shorted found)
all coils related to ssd are good nothing shorted.
all other bigcoils not including cpu area is good aswell.
unable to boot on dfu mode.
all usb c ports got same behaviour 5.19v-.22amp freeze. using orig 87w charger
U6960 VIN 0.6V and EN 0V not shorted
PPBUS_G3H 0.6v 0.216ohms
PP3V3_G3H_RTC_REG_R 0.1v 0.415ohms
tried my luck by replacing u6960 and u7000 nothing changes.
"using orig 87w charger"
This machine requires 96W charger!
Why did you touch U6960?
PPBUS_G3H MUST appear before 3V3_G3H_RTC.
Do you get 5V at R7020?
Check U7000 basic voltages.
A2141 turns on with 87W, if battery still holds some charge.
Get correct adapter first.
U7800 can't work before PPBUS_G3H is generated.
update:
injecting v on ppbus found leak on CA780 (PPBUS_HS_GPU)
after i removed ca780 now ppbus is 5.2V still no voltage on 3v3_g3h area
also still not turning into dfu mode.
