820-01814 5v 340mA-460mA
Dusty but no signs of liquid
One of the CD3215 would go 5V at .09A. Replaced and now all 4 ports give the same readings as far as power draw. 5V @ 340-460mA
PPBUS_G3H ramps to 12.14V then down then up every few seconds.
No shorts on PPBUS, 3V, 5V and SSD rails
When plugged in 3v3 cycling as well but is present but no 5V on the coil.
3v3 RTC is steady 3.34V
Did you test with charged battery?
Post diode mode to ground at 3V3_G3H_RTC.
Also check at all big coils; including SSD ones.
I did check SSD coils. .3-.400 diode. 3v3 G3H was not short as well. Customer chose to pick it up. Unable to continue diagnostic.
