820-01814 no image
"5v_s0sw_lcd - 1443"
Not sure what kind of reading is that.
Diode mode should be good enough to check; with LCD connected.
Once you connect something mor eon same line, diode mode readings should drop a bit.
Unless you've checked in reverse way.
You¡ve said U8500 gets power and enable; it should generate 5V_S0SW_LCD.
Just in case, replace C8509; also try another U8500 chip.
