820-01949 brain dead
Narek
Hi, I'm working on 820-01949 board which has slight coffee spill on it. Affected areas are R7439, some corrosion on caps around 7210 and U7100. R7100/7101 have been eaten away along with their pads. I have cleaned up all corrosion, replaced components, resoldered U7100 and recovered traces.
-Board starts, but doesn't show any image on the screen and there is no chime.
-Caps Lock doesn't light up
-When I put it into DFU mode Apple Configurator detects it but can't revive or restore - after some time of waiting "installing software" just dissapears and shows lock with status "booted"
-thermal camera doesn't show anything heating up
-tested with other battery - the same
-the only activity computer has is clikcing trackpad
Some basic measurements:
PPBUS_G3H - 12,72V
PP0V9_SSD0 - 0,9V
PPVCCQ_ANI_SSD0 - 1,8V
PP2V5_NAND_SSD0 - 2,5V
PP1V8_IO_SSD0 - 1,8V
PPVCCIN_S0_CPU - 0,601V
With 0.6V on VCORE, machine seems to boot.
It gets stuck for some reason.
You should check the board alone on the desk; just charger and USB tester connected.
Use USB-C hub with PD support; connect charger on it.
PLT_RST_L comes on?
Be aware, R7439 problem could caused an overvoltage and damaged PCH.
Narek
Board alone takes 20V and is floating around 0.075A.
PLT_RST_L is not comming on, it's flat 0V, it doesn't even spike.
Narek
No, CPU VCORE now is 0V. As I know this board needs to have good battery connected to boot, right?
Narek
With battery and charger there is VCORE. There is no VCORE when I connect just charger to board alone on the bench.
EDIT: Actually now I don't get VCORE. Battery and charger connected, board in topcase with everything connectes as before..
Narek
Yes, I trigger it and anyway VCORE doesn’t show up anymore, though I haven’t done anything to the board..
Corrosion around CPU power supply is very bad.
CPU may be damaged now.
You can try to heat it with quality flux; in case of accumulated crap underneath.
Check all resistors, caps and traces related with CPU power supply.
