820-01958 5v only
nik1981
Hi, I have a liquid damaged 820-01958 that is stuck at 5v with 0a
PPBUS_G3H:12.21v
PPDCIN_G3H: 5.16v
PP5V_G3S: 0v
PP5V_S5_LDO:0v
PP3V3_G3H: 0.949v
PP3V3_G3H_RTC: 3.269v
PP1V8_G3S: 0v
Any help would be really appreciated
nik1981
C7910 Pin 1 - LDO_Core = 1.463v
C7905 Pin 1 - LDO0 - PP0v8_SLPS2R = 0.00v
C7906 Pin 1 - LDO1 - PP3v3_G3H = 0.00v
C7914 Pin 1 - LDO2 - PP1V2_AWAKE = 0.00v
C7911 Pin 1 - LDO3 - PMU_LD)3_OUT = 1.80v
nik1981
Thank you for the reply 2informaticos.
R7900 is no stuff for me but pin 1 is at 0.610-0.620v
Coils diode mode:
L7806 = 0.007v
L7815 = 0.248v
L7814 = 0.248v
L7816 = 0.032v
L7817 = 0.032v
L7813 = 0.364v
L7819 = 0.448v
L7820 = 0.454v
L7822 = 0.440v
L7821 = 0.442v
L7823 = 0.362v
L7824 = 0.347v
L7810 = 0.207v
L7812 = 0.019v
L7811 = 0.019v
L7809 = 0.007v
L7808 = 0.007v
L7807 = 0.007v
Sorry, I was looking at wrong schematic (01598).
You may have bad U7800, or accumulated crap underneath.
Try heating with quality flux.
nik1981
With U7800 removed I'm still getting those low readings on diode mode. Could it be anything else before I order a U7800?
I expected it to alter the diode mode reading when removed
The diode mode readings on the coils are not caused by U7800, but T2.
You should compare the values with good board.
