Hello. I received a liquid-damaged MacBook with no power. The liquid primarily affected the audio board and its flex cable, causing a significant burn on the connector.
After replacement, the Mac powered on, but the sleep sensor was shorted. I replaced the right speaker (which contains the sensor), resolving the issue.
However, the MacBook now lacks audio output; both left and right speakers are quiet. Diagnostics revealed a short on the SPKRAMP_RESET_L line. I removed the associated resistor, capacitor, and U6400 Left Speaker Amp, but the short persists. This line originates from the T2 chip.
Is there a way to fix this issue? Thank you!
