820-01958 no power
Kyle93
Arrived with liquid damage around u7650. Before starting repair board was slightly turning on and charging battery.
After replacing U7650 and surrounding components board now only has a 12.30V PPBUS_G3H and power cycles every few seconds. Solders are good on U7650
What should be checked next?
Something else affected by liquid, possibly CPU, or other BGA chip.
You should inspect small resistors and traces too.
Kyle93
The resistors and traces have been inspected along with continuity testing. The minor spill occured only in the U7650 area.
PPBUS_G3H 12.33V
PP5V_S5_LDO 0.860V
Kyle93
Do you have a board view for this? The 820-01521 I have has different layout.
Also noticed the board is power cycling now. T2 chip in particular is heating up then cooling down on infrared camera every few seconds.
