820-01958 only 5V no power
modesto1993
Hi everyone, these days are hellish, there seems to be a general death of MacBooks, the one I'm analyzing today always has 5V on the PP20V line and nothing else, no liquid, no shorts on most of the lines I've analysed.
modesto1993
No 12V, no 3V, all the lines don't seem to be powered
Could the U7000 be faulty? PPBUS_G3H I have 0V
Difficult to help, if you don't provide useful information!
What is the voltage for PPBUS_G3H and 3V3_G3H_RTC?
If nothing, then check in diode mode.
modesto1993
All 0V, I corrected the back post above because I didn't remember the names of the lines I had checked. I think the problem could be U7000 but I'm waiting for your expert opinion.
modesto1993
yes, I had already dedicated myself to this resistor, with the tester measuring 0.18 ohm.
3V3_G3H_RTC is 0V but I didn't replace C6961, I diden't know if this could be the cause even if I see that it is a capacitor connected in parallel to others.
Update: I soldered a new capacitor and it works fine now. Problem solved!!! 🥳
modesto1993
Sorry, I didn't see the answer and I had updated my previous post, with the new capacitor everything worked! Thanks for the support 🤝😊
