Got this liquid damage board. I have 20V on usb-c meter.
With battery I get 20V 2A so it seems charging well, the fan spins also with and without charging cable. Without battery I get 20V 0.55A.
Board reacts to power button, opening the lid, pressing the trackpad or a keyboard key. I can see the fan stopping with 0A on the usb-c meter. an it goes back to 20V 0.55 when I press again the power button.
There is no image, no backlight and no boot, tested also hdmi with external monitor and disconnected internal lcd cable.
I have these voltages at the coils:
L7030 : 12,60V
L7690 : 3,3V
L7670 : 5,0V
L8410 : 0,08V (backlight coil)
L8100 : 1,2V PP1V2_S3
L8102 : 0,959V PPVCCIO_S0_CPU
L7702 : 1,035V PPVCCEDRAM_S0_CPU
L7270 : 1,021V PPVCCSA_S0_CPU
L7210 : 0,824V PPVCC_S0_CPU
L7220 : 0,825V PPVCC_S0_CPU
L7410 : 0V PPVCCGT_S0_CPU
L7420 : 0V PPVCCGT_S0_CPU
Tried a DFU revive then restore but nothing changed. SMC bypass also doesn't change anything.
Tried also the board with nothing connected and noticed suprisingly that without the trackpad cable plugged in the board will go to 20V 0,12 ->0,55A then after 3 secondes come back to solid 20V 0A at that time I will only have 3.3V and 5V. If I press the power button it will simply repeat 20V 0,12 ->0,55A for few seconds and come back to 20V 0A.
I don't know at this point what to look or check further...
Thanks
L7030 : 12,60V
L7690 : 3,3V
L7670 : 5,0V
Thanks
