820-01987 no boot
Sr. Robot
Hi, got an 820-01987 that turned off during use.
CPU gets hot but no image, no Caps Lock light.
U8250 was burned (no corrosion). Was replaced but i get no SENSOR_PWR_EN. Diode mode to ground is 0.750
PP3V3_G3H is 3.3v
Sr. Robot
I just noticed that the CPU only gets warm when J6801 is connected.
If J6801 connected i get 0.8v on CPU core coils.
If J6801 is not connected i get:
PPDCIN_G3H: 20.3v
PP3V3_G3H: 3.3v
PPVCC_S0_CPU: 0v
I wanted to discard U8250 failure; it can pulls down the signal in such case.
Not sure when in the power on sequence this signal comes high.
Sr. Robot
Got an U8250 from another board of the same model.
Now i got both SENSOR_PWR_EN and PP3V3_S4SW_SNS but still no boot.
Tried DFU but it gives error "AMRestorePerformRestoreModeRestoreWithError failed with error: 9" when installing system
