820-02009 - No S2 line
Palhano
iMac won't turn on! On the test button, LED 1 lights up and LED 2 blinks.
C7801 was shorted, I replaced it and the problem was solved. But the iMac still won't turn on.
PPBus_aon -16v
PP3v8_aon - 3.8
PP1v8_aon - 1.8
I didn't find any shorts on the secondary lines!
In diode mode, L8120 reads 0.090. But I don't have another board or references to check.
Any suggestions?
Palhano
I compared the L8120 line on an A2337 board, and it seems to be OK with that measurement.
Something strange happens: when I use isopropyl alcohol on the PMIC, the board powers on. I have the voltage readings for lines S2. LED 2 lights up normally, but LED 3 does not.
After the alcohol dries, the problem returns!
Which PMU is affected by alcohol trick?
If is MPMU, try replacing L8300; referenced to 820-02016 schematic.
Palhano
It's the U8100!
Should I swap the L8300 even though I have 3.8L on both sides (without the alcohol option)?
Palhano
The problem was actually an open L7800 capacitor. I replaced it and now LED 2 is stable, but LED 3 remains off.
Palhano
It works after assembly!
I've only worked on this model a few times and I'm still a bit confused.
From what I understand, LED 3 only lights up after the board is powered on; pressing the test button with the board disassembled doesn't make it light up.
Thank you for your attention!
