Working on M1 Air with 820-02016 board. Customer turned it off in the evening and in the morning couln'd turn it back on. Board has no signs of damages, corrosion or so. It doesn't switch to 20V, stuck at 5V and fluctuating between 0,038A to 0,13A. Trackpad doesn't click, can't get into DFU mode. Some power lines are pulsing (more info below).
Some basic measurements:
PPBUS_AON - 12,3V
PP1V8_AON - 1,79V
PP1V8_S2 - 1,78V -> pulsing
PP3V8_AON - 3,8V
PP3V3_UPC_LDO - 3,3V
PP3V3_S2 - 3,3V -> pulsing
I have measured lines around U8100/U7700 comparing with another good board. Found out, that PP1V0_S2SW_DRAM has 13,6ohm resistance to ground (0,006V in diode mode) compared to 69ohm and 0,039V in diode mode on good board. I'm asuming, that the RAM is damaged. If I connect the power there is 1V present on this line, but it's pulsing. Can it be the problem anyway? Another question - can I replace RAM chips P&P from another board without programming or so? I have plenty of these board for parts.
PPBUS_AON - 12,3V
PP1V8_AON - 1,79V
PP3V8_AON - 3,8V
