820-02016 left speaker issues
Sr. Robot
Hi, got an 820-02016 with bad sound on left speaker.
Tried 2 other speakers, no change.
SPKRAMP_A_OUTP, SPKR_ID0, SPKRAMP_A_OUTN diode mode test the same as good board.
Replaced UR600 just in case, no change.
You may have problems with UR900/10.
Compare diode mode readings with UR930/40 area.
Be sure all series resistors are good.
Don't forget RR600.
Sr. Robot
TDM_1V8_SPKRAMP_L_FSYNC and TDM_1V8_SPKRAMP_L_R2D_R were testing low so i replaced UR900, after replacing they tested good but still no change in sound.
Diode mode readings on UR930/40 area test the same as good board. Series resistors test good including RR600.
I didn't say to compare UR930/40 area with good board.
As right channel works good, you can take that area as reference and compare with UR900/10; I didn't know that you have a good board in stock, for comparison.
You may have a CPU problem...
