820-02016 no image
Kyle93
Arrived with no drop or spill damage. It will turn on and chime with backlight but no image on external or internal. After a couple minutes caps lock light can be turned on and off.
What should be checked next??
TCRScircuit
Super Moderator
The M1s likely need to be signed into the OS to give you image on external. You may need to have the internal display plugged in on the 820-02016 or else it will be stuck in the SLEEP 3 state.
If caps lock light comes on the machine is booted. Are you positive this is not no backlight? It can be very hard to see on the newer retina displays.
Kyle93
Yes since after the machine is plugged in as you hear the chime the screen itself brightens up some
Kyle93
Also tried connecting to external while the internal was connected as TCRS suggested, external backlight comes on as well but no image on either screen.
Backlight voltage is good, so the problem is with image only.
Looks like M1 graphics issue, if you miss internal/external image at same time.
Did you try PRAM reset?
Kyle93
Client said the issue just randomly started.
Tried DFU but it fails, even after failed DFU you can still hear the chime and the backlight appears.
What error did you get on DFU?
Can you get access to SSD in target Disk mode?
If yes, save data and try restore in DFU.
Kyle93
"Failed to restore device in recovery mode, libusrestore error 2015"
No reaction when trying target disk mode. Data is important.
"Failed to restore device in recovery mode"
Isn't correctly recognized in DFU mode?
Try forcing with SWV011; solder RV020, if not there.
You should get access in Target Disk mode also.
Turn it off, then maintain pressed T key; no need to press power button.
Kyle93
Turned back on only maintain pressing T key. Hear the chime but nothing else happens, nothing shows up on target mac. Caps lock light still reacts within a few minutes even after only pressing T key after being turned off
Try on all USB-C ports.
Also open Disk Utility on the other MacBook, to detect it.
Machine should turn on when you start pressing T key; maintain pressed and check in Disk Utility.
Kyle93
Tried all usb-c ports but no change. Nothing external ever shows up in disk utility. Other Macbook is running Monterey
The symptom points to M1; internal graphics issue.
But is strange that you cannot complete DFU, not get access in target Disk mode.
Looks like lost cause...
