820-02016 no power
Kyle93
Arrived with a burnt CD3217 and usbc amp meter going on and off every few seconds. Second port stays on at 5v
Replaced bad CD3217 from a donar M1 board but same issue. What should be checked next?
Kyle93
Replaced cd3217 from known good donar but same issue. Diode mode around DF602 is .168 but normal good reading is .130
diode mode around DF622 is .130
You may have damaged diodes, or capacitors on the USB-C connectors lines.
Compare readings with good board.
