820-02020 : 5V on DV, 20V on charger, no power
dudipupan
Ok, after removing UE501 (there was some corrosion on it I didn't see) the 1V25 rails are normal and I got 20V, 0.22A and stable PPBUS_AON on DC power.
Did you follow all the steps from DFU tutorial?
Try forcing the board in DFU with SV004/5.
Solder RV005 first, if not present.
dudipupan
Forcing th board in DFU worked. Maybe the keyboard is defective. But unforunately I can neither restore nor repair. It throws an "No such directory or file (NSPOSIXErrorDomain)" error...
