No-Clean
Clean board, when first came in one port had 20V and the other had 5V with battery connected, when checking the bad port PPVBUS_USBC0 had 0.5V when I as connected to the other port, after replacing UF400 that went away and now I have 20V on both ports but only with battery connected but 0A and obviously Mac is not charging, Mac boots because the battery still has charge, without battery I only get 5V 0.200A on both ports.
RF4/5xx are all fine.
PP5V_S2, PPHV_INT0_AONSW, PPVBUS_USBC0, PP3V3_S2_UPC, PP1V25_S2, PP3V3_UPC0_LDO, PP1V8_S2, USBC0_3V3LDO_EN, PP1V5_UPC0_LDO_CORE, PPVBUS_USBC0, PPHV_INT0_AONSW, USBC0_CC1 all measure correctly.
Tried reviving Mac in DFU and it did it just fine but same charging problem, I have not tried restoring it in DFU yet.
Not sure what to do, this is a first for me.
