820-02020-A camera issue (M1 2020)
A customer stepped on her screen and cracked it.
I replaced the screen and got a 'camera not connected' issue when testing in photo booth.
I put it down to a faulty camera in the display assembly (not the first time).
I replaced it again and the issue remains. Out of curiosity, I tested with the customers original screen and the issue is still present.
Has anyone experienced this before or know what I'm up against here?
The display cable looks fine and I cannot see any physical damage to the body of the unit.
I do not have FlexBV and the only schematics I can find for this one is a BVR file that can't be opened with openboardview so I am a little in the dark here.
Possibly the power rail fuse for camera is burnt.
LP610 goes to pin 46 of LCD connector, JP600.
Boardview available on the XinZhiZao server.
If the fuse is good, check the series resistors from data lines, LP602/3.
New LCD assembly, may not have ALS; is classic for chinese bullshits.
But the webcam should be good.
Check if ALS works with the original/broken screen assembly.
Try directing a flashlight to it.
Nothing appears on system report about camera?
That is because ALS is not detected also.
ALS and camera have common 5V power rail.
Check if you get 5V at T-CON camera connector.
And on this machine, one may not work alone; possibly ALS and camera must be both detected.
Sorry I'm not sure what you mean by t-con camera connector.
Both sides of the fuse show 5v.
Or do you mean on the display board? If so, the test points arent marked..
On that board should be a small connector for camera.
Disconnect it and check if 5V arrives there, on any pin.
You can check in buzzer mode (without power), if 5V ALSCAM line has continuity with something on T-CON board.
Remove T-CON from cracked screen assembly and check where the 5V ALSCAM should arrive on it.
You may have problems with the video cable from MLB to T-CON.
