820-02020-A Macbook Pro M1 bootlooping/power cycling
bogosort
Hello,
I managed to repair a liquid damaged 820-02020 board. There were two shorted capacitors.
However, the laptop is stuck in boot looping. Everything is connected correctly (battery, trackpad...)
I cannot even get to the boot option selection screen by holding the power button.
I cannot get into DFU mode neither.
I managed to get to the login screen once, but I can't get to it anymore.
Video here:
https://streamable.com/2ayubc
Here is a video of the amp meter:
https://streamable.com/k57gd5
PPBUS_AON starts at 12.33v then drops to 12.04v a second after plugging it in
I can also hear a clicking sound when it power cycles (right when shutting off)
Any idea?
Thank you!
Which area has been affected by liquid?
Did you try connecting both charger and known good battery (holding some charge)?
bogosort
Thanks for the welcome!
The two shorted capacitors were CR608 and CR606.
I see signs of liquid damage around UC300, CR605, CR607, CR635, CR637.
I don't remember the other areas since I cleaned it a while ago.
I unfortunately don't have the original charger for this one, I do however have a third party that goes up to 96w and an official charger for an A2442 Macbook Pro 14".
I thought it could be related to the battery since the only time I could get to the login screen was the first time I tried to power on the laptop with the battery connected. Since then, even when disconnecting the battery and reconnecting it, I can't get to it anymore.
I do want to mention, however, that the battery seems to hold a charge and can power on without a charger plugged in (but shows the same behaviour as originally explained)
Very dangerous if corrosion extended under audio amplifiers (UR600/30).
Many data lines go directly to M1 processor; leakage from PPBUS_AON may destroy it.
Corrosion on UC300 area is also dangerous.
Do you get correct 5V_S2 now?
Also check 3V_S2 voltage.
3V8_AON is stable?
Write directly into reply box, instead of clicking Reply button.
I don't see any reason to quote an entire post, visible few centimeters above.
Please, maintain forum aesthetic...
bogosort
5V_S2: 5.19V
3V_S2: 3.3V
3V8_AON: 3.8V, stable
When putting red probe on ground, black on L5800 in diode mode, I get a reading of 0.161
