HeyWatchOutDude
I have a MacBook Pro M1 which doesn't recognize the battery (0% - Cross Icon).
PPVBAT_AON (with charger and battery connected) = 11.96V
PPVBAT_AON (without charger and battery connected) = 1.4V
PPVBAT_AON_CHRG_REG = 11.96V
PPDCIN_AON_CHRG_R = 20V
I assume the board is fine because both MOSFETs (Q5230/40) are testing good.
Note:
- I can successfully boot into macOS (fan is going high due of the not detected battery).
- At the first boot it crashes and then boots again into the OS.
- Sadly I don't have another battery for testing .... :/
- No battery information available under "System Report" (Cell version, hardware version, firmware etc.)
- Battery voltage (+/-) is 2.1V, pretty low.
Battery board (820-00392-A):
- Two PINs (red arrow) are connected to each pad of the flex, is that normal? (at least I measured "continuity" with the multimeter)
(Check attachment)
Note:
(Check attachment)
