Sykulski
I have this 13" M1 which had liquid damage. The trackpad connector was burned. After replacement of trackpad connector and flex machine boots and trackpad is working.
But when I connect the power supply to the USB-C port to charge the battery the screen turns pink for a while and the machine reboots.
I have tried minimal configuration with only a known good battery, a known good display and a known good USB-C board. The error remains with only these three peripherals connected to the board.
Machine charges fine (as long it is started up with the charger already connected). I can connect external hard drive and external display which both works fine. It only crashes when I connect charger.
I have also tried to restore a fresh installation of Monterey in DFU mode to rule out a software issue.
Link to video of what is going on:
What to do next?
What to do next?
