820-02020 no power
Kyle93
Arrived with no power and only 5v with UF500 Port power cycling. Replaced UF500 and UF400 from good donar board but no change. DZF664 had a burn mark on it. Replaced it but also no change. PP3V3_AON i8s 0v. UF400 power cycles as well except stays at 0v 0amp
What should be checked next?
Did you maintain correct postion for UF400/500 when replaced them?
Remove F5200 and check C5250 voltage.
So your problem resides on a secondary power supply.
First, check diode mode to ground at F5200 output pad.
Also check on 3V8_AON, 3V3/5V_S2.
Only UF500 port cycles within two seconds with 0 amp draw while UF400 draws 0.150amps and takes several seconds to power cycle. Are you sure something in USB-C area does not need to be checked?
PPBUS_AON and 5V_S2 are stable
power cycles on off on amp meter still occur on both ports. UF400 goes up to 0.104amps before cycling which takes several seconds however UF500 port just stays at 0v 0amp and cycles every other second
which specific things should be checked? Ive compared diode mode readings to both areas and everything matches
