PPVDD_PMU_LDO_PREREG - diode 308 , 0v
PP1V5_VLDOINT_MPMU - diode - 240 , 0v
PP1V8_S2 - diode 337 , v 0v
PP3V8_AON_MPMU_ISNS_VIN 348 , voltage jump some like 0,14 - 0,72 - 1,61 v and go around and rising
PMU_VDD_HI diode 586, voltage same like pp3v8
PP1V25_ 2 - 276 , 0v
VSS_ANA_MPMU - short
PP3V8_AON_SPMU_ISNS_VIN - short on leg 2 - 0v , leg 1- 348 - voltage jumping circuit
PP1V5_VLDOINT_SPMU - 276 , 0v
PP3V8_AON_SPMU_ISNS_VIN 347 . voltage jumping circuit
PP5V_BSTLQ_SPMU 442 , voltage jumping circuit
short on line PP1V06_s2sw_dram
PPVDD_SOC_S1
PPVDD_PCPU_AWAKE
"PP3V8_AON_SPMU_ISNS_VIN - short on leg 2 - 0v , leg 1- 348 - voltage jumping circuit"
Legs 1 & 2 of who???
How can you have short on a rail coming from 3V8_AON (through 5 miliohm resistor)?
"short on line PP1V06_s2sw_dram"
What exact ohm value?
Compare with good board, if no pure short.
"PPVDD_SOC_S1
PPVDD_PCPU_AWAKE"
Short to ground also?
Ohm scale readings?
