Isolated
I have a liquid damaged 820-02098 M1. No corrosion around CD3217 areas. Corrosion is located from UR500 to C8012 if that helps. UR500 was the worst and has been removed due to creating a short, waiting on replacement but the board should still work without once fixed, correct?
PPBUS_AON - 12.4v (ISL9240 replaced)
PP3v8_AON - 3.8v
PP5v_S2_MAIN - unstable
PP3v3_s2 - unstable
PP1v8_S2SW - unstable
PP1v8_S2 - unstable
PP1v2_s2 - unstable
PP1v2_AWAKE - unstable
PPVDD_ECPU_SRAM_AWAKE - unstable
PPVDD2H0_S2SW - unstable
PMU_VDDHI - 4.9v
I don't have much experience with the new power sequencing of the M1/2/3 devices but it seems that the S2 rails are generated by U8100/U7700? Is that why the S2 rails are cycling due to bad PMU, is the M1 CPU dead? I have schematics and boardview.
Thank you for any help or tips!
PP3v8_AON - 3.8v
PP3v3_s2 - unstable
PP1v8_S2 - unstable
PP1v2_s2 - unstable
PMU_VDDHI - 4.9v
