820-02098 (A2442) Power Rebooting
jxx
Hello, this is the 820-02098 (A2442).
There was no water damage.
20V boots normally, but it keeps turning off and on.
There seems to be no short value when testing diode mode.
- PPBUS_AON 11.98V (when turned off) 12.27V (when turned off)
- PPVIN_P3V8AON 11.98V
- PP0V9_ATCRTMR2_SVR 0V
- PP5V_S2SW_USBC23 0V
Where should I test it? I would appreciate it if you could let me know.
Thanks
DFU should solve such issue.
I tried revive, restore with IPSW but it does not work.
"AMRestoreErrorDomain Failed to receive message from device, might be connection problem with USB host. (Communication error, possibly USB disconnection)) [AMRestoreErrorDomain – 0x9 (9)"
It's reboot during installation after 10~15minutes. that's why fail.
When connected without a battery, dfu mode doesn't work and turns off. 5v -> 0v -> 17-19v -> 0V
