820-02098 power cycling
Kyle93
This arrived with no liquid damage. Power cycles every few seconds. Board looks pristine. Checked all coils and do not see any shorts.
When magsafe or usb-c is plugged in they both turn on for two seconds then off then on. All voltages appear as well.
What should be checked next?
Kyle93
Same issue is occurring with F5200 removed. C5250 voltage goes to 12.30v then drops to 0V while magsafe or usb-c is plugged in as they go off and come back on
Then you may have problems on the charger side; USB-C and Magsafe areas.
I recommend to check diode mode readings around U5200 and compare with good board.
You should check Q5230/40 too.
Kyle93
Checked diode mode in those areas and all of the readings are very close to a known good board.
Kyle93
Still waiting to hear back.
Diode mode readings match a good working board. Is there anything else that can cause this issue?
Post U5200's basic voltages (keep F5200/1 removed): P_IN, AUX_DET, VDDA/P, EN_MVR, AUX_OK, A/BMON.
Any fluctuation?
Kyle93
P_IN flucuates up to 0.430v
AUX_DET 1.3V stable
VDDA/P 5V stable
EN_MVR - flucuates up to 0.465v
AUX_OK 0.056- 0.890v
A/BMON 0V
U8100 is not involved yet, when F5200/1 are removed.
You should get stable C5250 voltage.
If not, you have problems on U5200, or power input areas.
U8100 may be bad, but remains to test later.
First, resolder the fuse.
Check diode mode to ground on all secondary power rails.
Also check U8100 and U7700 LDOs.
Kyle93
PPVDD_ECPU_AWAKE is 0.633V
Removed L8200 diode mode on U8100 side is 0.525 while other side is 0.25
Is this bad M1?
