820-02098 stuck on 5v and no boot
this board was shorted at ppbus because of ug800. i've replaced ug800 and still no 20v. what's the function of UG800? is pp5v_s2sw_usbc23 important?
This voltage powers on external devices connected to ports 2 & 3.
Is the machine recognized into DFU?
it will not enter dfu mode. the amber indicator on the magsafe turns off for a second whenever the power button is pressed
i'm not familiar with the apple silicone boards. i checked 3v8_aon and ppbus_aon and both are present but the ppbus is only 12.1v
the amp meter show 5v .900 amps and i just let it sit for a few hours. that's must've charged up the battery because now it's booting but not charging. Now all ports show 20v .000 on amp meter but only with the charged battery attached
So you should have problems on USB-C chargeing areas.
When machine boots (with battery), do you get USB activity and external video?
Check on all ports.
there's no activity on any of them. ug400 was visibly burned when i first started the repair and the first thing replaced
