820-02100 Power off after water damage
jxx
Hello, this board has water damage.
It goes up to 20V, then turns off and on again. I keep repeating. It boots normally when turned on with the battery but won't charge.
There was water damage in the UG400 (CD3217), and I replaced the UG400 and peripheral capacitors. The symptoms are still the same.
There is no particular short value when testing the diode.
There is no PP0V9_ATCRTMR2_LVR voltage value. (There is no diode test short.)
There is no PP3V3_ATCRTMR2_SVR voltage value. (There is no diode test short.)
There is no PP3V3_S2SW_USBC2 voltage value. (There is no diode test short.)
CG400 of PP3V3_S2 circuit was corroded and replaced, and now it is 3V3.
If machine works with battery, there your problem is located in the USB-C area.
"I replaced the UG400"
Where did you get it from?
MUST come from same donor board, maintaining its position in boardview.
jxx
이 기기가 배터리로 작동한다면, 문제는 USB-C 영역에 있습니다.
"UG400을 교체했습니다"
어디서 알아냈어?
MUST는 같은 기부자 이사회에서 나왔으며, 이사회에서 그 위치를 유지했습니다.
Thanks to reply
I get it from same donor board and same location.
Even before replacing the Ug400
It was same problem.
All USB ports have the same behavior?
Check with Magsafe 3 charger also.
Compare diode mode readings around all CD3217 chips; start with their LDOs.
jxx
Yes, all ports have the same symptoms.
MagSafe 3 works fine also charges well.
Around CD3217 diode value looks fine except above values.
jxx
I don't know why, but the symptoms suddenly disappeared and everything is working fine now. Anyway, the problem was CD3217.
