820-02536 5V 0.100A
Hello.
I have no experience on M1/M2 boards. I started to read and tooks the measurements below.
Any advace will be appreciated.
Wont switch to 20V.
Takes 5V and 0.100A
Same behaviour on Magsafe and both C ports
MB looks clean. Couldnt find any blown component nor liquid damage.
Diode:
PPBUS_AON: 589
PP3V8_AON: 542
Voltages:
F5200(PPBUS_AON): 12.3v
L5800(PP3V8_AON): 3.8V
LC320 (PP5V_S2): 5.17V
L8290 (PPVDD_S1_DCS): 0.7V
U7700
PP0V72_S2_VDD_LOW: 0.74V
PP1V8_AON_SPMU: 1.8V
PP1V2_AON_SPMU: 1.2V
PP0V78_S1_VDD_FIXED: 0.8V
PP1V5_LDOINT_SPMU: 1.49V
U8100
PP1V8_AON: 1.79V
PP3V3_S2_LDO: 3.2V
PP1V2_AWAKE_PLL: 1.2V
PP1V8_AON_MPMU: 1.79V
PP1V2_AON_MPMU: 1.2V
PP3V3_AON: 3.3V
PP0V855_S2SW_CIO: 0.857V
PP3V3_S2SW_SNS: 3.29V
PP1V2_S2_CIO: 1.2V
PP1V5_LDOINT_MPMU: 1.8V
Still stuck at 5V if you connect a charged battery?
Did you also test the board alone, disconnecting all accessories, apart of charger?
Voltages look good.
This doesn't assure there is no internal NAND failure.
If no important data, you can try DFU restore.
However, should be good to test with known good battery first.
I am really struggling to get a good battery to test.
What else can I measure? Customer mentioned the screen was replaced and after 1 week it turned off while working.
As per schematic (page 109), UF260 and U5560 are the programmable ROMs for power input.
Even CH341 can do the job; just need correct adapter to solder it.
Don't forget to make backup.
I don't have TBT ROMs for new machines...
