820-02536 A2681 M2 Air - No power 5V - 0.05A ~ 0.23A
ronaldo
I need help with this, please.
MacBook Air A2681- 820-02536
I got this MacBook from a customer which is not turning on; it has no display. It's stuck on 5V
Does not recognize in DFU mode.
No signs of liquid.
These are the readings.
MacBook Air A2681 / 820-02536 — Measurements Summary​
Symptom​
  • Stuck at 5 V
  • 11-second cycling pattern
  • Additional 4-second sub-cycle observed on PP0V88_S1
  • Battery not connected (charger only)
  • DFU mode: no detection
  • PP1V05_S2SW_VDD2H at 0.050 V confirmed normal against good board reading of 0.043 V
Live Power Rail Measurements (charger connected)​
RailReadingBehaviour
PPBUS_AON12 V → 12.3 V → 12 VCycling every 11 s
PP5V_S25.19 VCycling every 11 s
PP3V3_S23.29 VCycling every 11 s
PP3V3_AON3.3 VCycling every 11 s
P5VS2_PWR_EN1.8 VCycling
PP0V88_S10 V → 0.80 VCycling every 4 s
PP0V779_S1_SRAM0.78 VPresent for a couple of seconds
PP1V25_AWAKE_IO1.25 VPresent for a couple of seconds
PP2V58_AWAKE_NAND_VCC2.59 VPresent for a couple of seconds
PP0V88_S10 VNever comes up (initial measurement)
SOC_XTAL24M_IN0.58 VSteady
U5700 Pin Readings​
PinSignalVoltage
8PP3V8_AON3.8 V
7PP5V_AON5 V
5P3V8AON_PVCC5.19 V
12P3V8AON_PWR_EN_R4.79 V
U5200 Pin Readings​
SignalVoltage
P_IN5.1 V
AUX_DET0.84 V
SMC_RST_IN0 V
VDDA4.79 V
VDDP4.79 V
EN_MVR4.79 V
AUX_OK1.76 V
A_MON0 V
B_MON0 V
PMU LDO Output Readings​
RailVoltage
PP1V8_AON_MPMU1.8 V
PP1V2_AON_MPMU1.2 V
PP1V8_AON_SPMU1.8 V
PP1V2_AON_SPMU1.2 V
Diode Mode Readings.​
NetReadingNote
PP5V_S20.311Normal
PP3V3_S20.485Normal
PP1V8_S20.258Normal
PP1V25_S20.216Normal
PP0V855_S2SW_CIO0.251Normal
PP1V05_S2SW_VDD2H0.050Normal
PP0V88_S10.340Normal
BUCK12_FB (at R77C0)0.330Normal
IR Camera Observations​
During the 11-second cycle:
  • U5340: heating/glowing
  • RC622, RC623, RC624, RC625, RC626, RC627 (All connected to PP5V_S2 power line all glowing momentarily) Diode mode readings on these components are correct
  • UF400 slightly warmer than UF500 and other CD3217s
